UCM 6.12 Database Replication Status
Answered Question
May 5th, 2009
I had some problems with phones registered to my subscriber and had to reboot. Is it normal in real time monitoring tool for the replication status on the subscriber to be 0? Both the publisher and Cluster show a status of 2.
Correct Answer by jguggehe about 7 years 12 months ago
You might want to try a utils dbreplication reset all
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/7_0_1/cli_ref.html#wp62592
Give it about an hour or so and see what your replication status is.
Hope this helps! If you find this post useful, please rate it.
John
Overall Rating: 5 (1 ratings)
