Cisco Fax Relay to T.38 Fax Relay
Answered Question
May 5th, 2009
  • Bronze, 100 points or more
Is it possible to convert with the help of a CUBE(IP2IP) incoming Cisco Fax Relay transmissions to T.38 Fax Relay format in the outgoing?
thanks,
met
Correct Answer by Nicholas Matthews about 8 years 3 weeks ago
Hi Met,
CUCM is signaling only. You can put CUCM between your signaling endpoints, but it's not going to change any of the media since all of the media is directly between the endpoints. CUBE in this case is a back-to-back user agent so it terminates each end of the call.
-nick
Overall Rating: 5 (1 ratings)
Nicholas Matthews Tue, 05/05/2009 - 15:10
  • Red, 2250 points or more
Hi Met,
Unfortunately this isn't possible. The DSPs do not currently have support for this, nor do I know of any plans to support it.
The popular workaround is to put a back to back PRI on CUBE and do CFR---PRI--(loop)--PRI--T38
hth,
nick
metalium2007 Wed, 05/06/2009 - 00:46
Thank you very much for helping me.
And can't i use a CUCM in the middle?
thanks again,
met.
Correct Answer
Nicholas Matthews Wed, 05/06/2009 - 04:33
Hi Met,
-nick
