Quick Route Map Question
May 5th, 2009
  • Blue, 1500 points or more
How come my static route is getting redistributed properly, yet the route map and access-list dont show any hits?
switch2#sh run | be router eigrp
router eigrp 10
redistribute static route-map STATIC
network 1.1.1.1 0.0.0.0
switch2#sh route-map
route-map STATIC, permit, sequence 10
Match clauses:
ip address (access-lists): 10
Set clauses:
metric 10000 1 255 1 1500
Policy routing matches: 0 packets, 0 bytes
switch2#
switch2#
switch2#
switch2#sh access-lists 10
Standard IP access list 10
10 permit 100.100.100.100
switch2#
John Blakley Tue, 05/05/2009 - 13:37
  • Purple, 4500 points or more
Victor,
I set a couple of routers up exactly like you have yours, and I see hits on the acl but not on the route map. Could it be inherent to the switch or IOS?
HTH,
John
lamav Tue, 05/05/2009 - 13:41
I dont know..I bet if I searched the Internet high and low, I would find the answer....just dont have the patience for it now...
