Second NIC on Call Manager 7.01
May 5th, 2009
  • Bronze, 100 points or more
Is there any possibility to use the second nic o CUCM 7.01 in a different network?
Is it just unsupported or really impossible to configure?
thanks,
met.
James Hawkins Sun, 05/10/2009 - 13:07
  • Gold, 750 points or more
As far as I am aware it is impossible to set separate IP addresses for NIC1 and NIC2 in any LINUX based CUCM release.
You can set the NICs for active/standby but that is all.
Out of interest why do you need to put the second NIC in a different network?
metalium2007 Sun, 05/10/2009 - 13:24
Hello jamesha, thanks for your thoughts, i already realized that!
Well why? Good practice to have one service interface and one management interface.
Thanks!
Sascha Monteiro Sun, 05/10/2009 - 14:52
  • Silver, 250 points or more
I am not sure if it's good practice for servers though..
If you would have 2 nic's with seperate subnets, you can easily introduce faults by i.e. configuring incorrect routes etc.
We use iLo however, which is on a seperate subnet, and with advanced license you can even connect to the CLI interface. (only when things turned to custard ;-) )
