FXO finding if line is plugged in
Endorsed Question
May 5th, 2009
Is there a way on a VIC FXO to find out if there is an actual line plugged in to it?
I know on a Linksys Gateway SPA400 the minute you plug the line in, the voltage indicator will change; which indicates that it's actually plugged into something. Is there a similar info on a Cisco FXO or something similar?
Thanks.
Cisco Endorsed by Jose Carlos Zamora Araya
paolo bevilacqua about 8 years 3 weeks ago
Not really. You can attempt a call with csim start and on a disconnected port you you see lack of current loop when off-hook, with "debug vpm signal"
Overall Rating: 3.8 (9 ratings)
paolo bevilacqua Tue, 05/05/2009 - 14:15
  • Hall of Fame,
    Founding Member
kherzog Mon, 08/03/2009 - 19:26
On the ISR router with a FXO port you can also use a command to verify voltage for the voice port. There is a Cisco document that details the command used below, it will report if there is any voltage on the fxo port in question. I used this command to remotely troubleshoot an outage report for an overhead paging system. The paging system is providing the voltage/battery. If this was a CO type line, then, again the PSTN is providing the battery, so if it is connected to the fxo, you must have voltage.
Example:
> term mon
> test voice port port# si-reg-read 29 1
> A value of 0x00 indicates there is no voltage being seen on the line/voice port.
> You need the terminal monitor command to see the output of this command on the screen.
homegw-220#ter mon
homegw-220#test voice port 3/0/2 si-reg-read ?
<0-200> Starting register in decimal: 0 - 200
homegw-220#test voice port 3/0/2 si-reg-read 29 ?
<1-6> Number of registers to be Read: 1 - 6
homegw-220#test voice port 3/0/2 si-reg-read 29 1
homegw-220#
Jun 18 2009 16:44:53.629 EDT:
Values read from SiLabs Codec connected to DSP 0, channel 2:
Register 29 = 0x00
Jun 18 2009 16:44:53.629 EDT: >
paolo bevilacqua Tue, 08/04/2009 - 03:35
  • Hall of Fame,
    Founding Member
To the person that rated my post an "1":
you're misusing the rating system, because the information that I gave is correct to the best of my knowledge, and given in good will.
Robert Dantes Fri, 10/25/2013 - 16:27
I know this thread is kinda old but incase anyone passes by this thread looking for an answer to the same question as the original poster.
test voice port x/x/x   si-reg-read 29 1
This command can help in detecting if the line connected to the port has a current; Need to look for anything not 0x00. since 0x00 means no electric current
Robert Thomas Fri, 10/25/2013 - 21:04
  • Silver, 250 points or more
Although relatively simple I use a "show voice port summary" and then call into the FXO line. You will see the port chaning status to ring-detected, if the status show no change, then there's nothing connected.
