Adding Multiple DC's to Unity 4.0 system
Answered Question
I have a unity 4.0 system and want to add multiple DC's to the unity server. On the unity server there appears to me a field to enter a 2nd DC but it is grayed out. I have done some research and it appears this is not a license issue.
Correct Answer by Christopher McAlpin about 8 years 2 weeks ago
Actually the DC/GC Reconnect Tool only allows you to configure the DC/GC that Cisco Unity's directory Monitors (AvDSAD and AvDSGlobalCatalog) use to synch with Active Directory.
In the situation you describe where messages are not delivered after a reboot of the DC, I have to assume the DC is also a GC, you would want to look at the GC that MAPI is using, not the DC/GC that the directory monitors are using.
See the following:
When GC is down, voicemail is not delivered
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCea26846
Correct Answer by Bradford Magnani about 8 years 3 weeks ago
Ah... yeah, you'll need to manually edit the registry:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/42/upgrade/guide/ex/ru_070.html#wp1061159
Hope that helps,
Brad
Yep, that's where the DC/GC Reconnect Settings tool comes into play as I discussed.
Overall Rating: 5 (3 ratings)
Bradford Magnani Tue, 05/05/2009 - 20:09
  • Cisco Employee,
If you're referring to the DC/GC Reconnect Settings tool, in order to cause the Manual Primary and Manual Secondary fields to become active, you need to uncheck "Enable Automatic server search functionality on reconnects for this domain". It'll then allow you to enter values into each field.
Hope that helps,
Brad
Bradford Magnani Tue, 05/05/2009 - 20:24
  • Cisco Employee,
I'm not sure what you're referring to, can you be more specific?
Correct Answer
Bradford Magnani Tue, 05/05/2009 - 20:29
  • Cisco Employee,
Bradford Magnani Wed, 05/06/2009 - 08:19
  • Cisco Employee,
Sure, providing the DC/GC is reachable in a timely fashion, there should not be any interruption of service if all goes as planned with the switch to the backup.
Brad
Correct Answer
Christopher McAlpin Wed, 05/06/2009 - 10:33
  • Cisco Employee,
See the following:
