Routing between Leased Line & Frame Relay Connection
Answered Question
May 5th, 2009
Hi Cisco Experts,
Based on my attachement, I need your advise on how to route packets from Frame Relay users to Leased Line users with different Gateway. If I will be using the 192.168.0.102 gateway, I can access the 192.168.4.0 network but not the 192.168.2.0 network. But if I use the 192.168.0.41 gateway, I can access the 192.168.2.0 network but not 192.168.4.0 network. What will be the solution for this problem. Is it routing only or need to add another NIC for the other gateway. Hope you could help me regarding this matter.
Raymond
Overall Rating: 5 (1 ratings)
