Show proc cpu occassionally high
May 5th, 2009
Dear Friends,
The CPU utilization for a 6500 with Sup 720 and IOS version 12.2(33)SXH3(is occassionally high. But when i try to get in and issue the command sh proc cpu sorted 1min, the CPU utilization is low at that time.
Please find enclosed the output of show proc cpu history
I am not able to capture the suspect process that caused the high cpu. This has been happening repeatedly for 1 month. However, the average CPU remains low. I am not sure if its ok.
Once when i got in the 6500 switch, it told me that HSRP Input was around 4%. When i put in the output of show proc cpu in Output interpeter, it said that everything is ok as no process is beyond 10%.
Kindly suggest if this is normal behaviour or it is something that requires further investigation.
Thanks and Regards
Gautam
route2null Tue, 05/05/2009 - 23:28
From the information provided it looks OK to me. But there are lots of possible caveats. What led you to check the switch cpu? Are you troubleshooting a problme?
James
gautamzone Wed, 05/06/2009 - 00:12
Dear James,
We are getting alerts through NNM that the CPU utilization is high sometimes.
But at the time of checking, we see that the CPU utilization is within 10-20%.
Thanks a lot
Gautam
Joseph W. Doherty Wed, 05/06/2009 - 03:19
What values does the NMS alarm on? Short term CPU isn't totally unusual if there's some recurring control plane processing. Perhaps your NMS just needs to relax its alarm criteria a little.
pompeychimes Wed, 05/06/2009 - 06:25
  • Bronze, 100 points or more
Like Joe said its probably a hair trigger on the NNM. I'm not a fan of HPOV (I assume you are refering to HPOV NNM) so i don't use it. However, I'm sure it has a feature to allow you to monnitor the cpu over time. If not there is plenty of free / trial stuff out there.
