SSL VPN via Three WAN IPs on the same ASA
May 5th, 2009
Hi All,
If a single ASA 5510 (4 ports) connects to 3 different 857 ISR routers. On each port of the ASA 5510 (outside1, outside2 & outside3) the WAN IPs are of different subnets. The 857 routers only provide the ADSL connection and nothing else.
The 4th ASA port is the INSIDE port connecting to the inside LAN network.
Is it possible for the ASA to allow SSL VPN connections if it is enabled on all the 3 outside ports ?
And then have three different default routes such as
route outside1 <WAN IP of connected 857 router 1> 1
route outside2 <WAN IP of connected 857 router 2> 1
route outside3 <WAN IP of connected 857 router 3> 1
Is this possible ?
thank you.
