what is a backplane
May 5th, 2009
Hi. I did some reading on backplanes and from what i gathered it is a bus to connect the router/switch. What i don't understand is what is real purpose/function of a backplane. Forgive me if my question seems very simple.
Thanks in advance for your indulgence.
route2null Tue, 05/05/2009 - 23:46
You described it yourself. It's a bus. To expand a little it's a medium over which all the components of a device can communicate.
marcusbrutus Tue, 05/05/2009 - 23:57
Sorry, i'm still a bit confused. I know that a bus is used for communication between components. What i don't know is what are its practical usage. I mean, let's say i have a 2960 switch with a certain bus, i have connected the switch to my workstations and everything is working just fine. How or where does the backplane get into the picture?
Thanks.
Hi Marcus
My simple analogy is that I think of the backplane as the mother board/main circuit board of the switch. It allow the CPU, DRAM, FLASH, ASICS communicate within the switch, which facillitate the switch functioning as required/expected.
If all you had inside your switch was a green board with these components and all the rest just plugged into slots on the board with no way to communicate, then all you would have is a pretty hefty paper weight :)
It's probably not the best analogy but it is the way I think of the backplane.
Best Regards,
Michael
marcusbrutus Wed, 05/06/2009 - 00:09
Hi. Sorry. I think i finally got it. The backplane is the motherboard in a router/switch right?
deepa.muralidharan Wed, 05/06/2009 - 00:41
As explained, backplane is a circuit biard that connects several connectors in parallel to each other.
Switch backplane generally refers to the switch fabric. When we talk about the switch backplane capacity, this refers to the maximum throughput when the switch is fully in use.
Joseph W. Doherty Wed, 05/06/2009 - 03:38
Backplane is the discreet circuitry that allows different computer components to communicate within the system's frame. A good example within a network device would be a chassis system. When you insert a card, it connects to the backplane. Also see: http://en.wikipedia.org/wiki/Backplane
Generically the term backplane also becomes the "glue" for internal system data communication. For instance, on a modern appliance switch, the "backplane" could be a combination of circuit traces and ICs that support communication between switch ports.
