ASA5505 - Http & Telnet Autentication
Hello All,
I have managed to get my ASA5505 to authenticate IPs for cut though proxy using Telnet and it works great.
However I want to use only Telnet for authentication and if a user has not yet authenticated and then opens a browser session they are greeted with a login screen. Is it possible to switch this feature off?
nomair_83 Wed, 05/06/2009 - 03:14
  • Bronze, 100 points or more
You can allow only telnet traffic using cut through feature.
Not true Nomair_83.
You can use cut-though for any protocol but only Http(s), Telnet and FTP as authentication methods.
"access-list auth_users extended permit ip any any
aaa authentication match auth_users inside LOCAL"
Above is an extract from my config, users on the inside can not access outside unless they authenticate.
I want to know if I can switch off HTTP authentication.
nomair_83 Wed, 05/06/2009 - 04:28
My friend,
Thats what I meant, just allow telnet traffic in access-list rather then permit ip any any.
access-list auth-users extended permit tcp any any eq 23
If I do that the user will not be able to access the internet.
I want users to authenticate using telnet then be able to access Http.
I don't want them opening a browser and be prompted with the authentication prompt.
(I have a 3rd party application that will use telnet to authenticate the user transparently first.)
