load balancing or load sharing
May 6th, 2009
  • Bronze, 100 points or more
What is the actual difference between both these terms in the context when there are 2 links to internet.Does it mean both links would be used simultaneously in particular proportion or does it indicate either of links will be used one at a time,but not together?
Thanks in Advance.
cisco_lad2004 Wed, 05/06/2009 - 05:31
  • Gold, 750 points or more
Good question!
I stand corrected, but I would say its the same concept.
Per destination load balancing, could either lead to a link used constantly at all times if all packets are going to same destination. or 2 or more links used at same time for different destiantions.
The end results is that the load is shared over more than one link....load balancing.
Sam
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml
