How to add users massively to ACS 4.2
May 6th, 2009
I have to migrate the RADIUS service from a third party vendor to ACS 4.2. I have around 4000 users defined, all of them with a fixed IP address assigned. I know I can create a file containing users/passwords in order to populate the ACS user's database. But my question is if there is any way to assign an IP address to these users in the same (or in other) file using the ACS command line.
darpotter Wed, 05/06/2009 - 11:54
Yes there is - RDBMS Sync.
docs here:
You'll see a whole load of action codes to add a user, set password, group membership etc. But action 150 sets a static assigned ip address.
It can take a bit trial and error to get it working, but once you get the hang of the syntax its easy and you can easily script the creation of your actions file.
If you have the s/w ACS you can use a csv file, xls or ms access db. You then create a System DSN pointing to the actions db and reference the DSN from ACS. When you initiate the dbsync import it first parses the data then processes it.
Also on the s/w ACS there is a command line to do a parse-only scan of the account actions - try csdbsync -x to get help.
