prakashj Wed, 05/06/2009 - 22:28
We have CVP server it contains Call Server, VXML Server and Media server.
We have configured Call Server, Media Server successfully on the CSS.
We have the same document 7.0 config guide.
But we are not able to succeed on vxml server configuration. because we are coping index.jsp document all possible location but still it not coming alive, if any one knows where exactly need to copy in cvp sever, it would be helpful.
Muhammad Amir Raza Thu, 05/07/2009 - 01:46
  • Silver, 250 points or more
Kindly find below CSS running configuration.
service VXML1
ip address 1.1.1.1
port 7000
keepalive type http
keepalive port 7000
protocol tcp
keepalive uri "/CVP/Server?probe=true"
active
The default is to pull the Apache JSP page installed on the system. That is, "uri=/index.jsp". There may be a mistake in the documentation that omits the leading slash.
This works just fine also. You don't have to put it anywhere - it already exists in Cisco\CVP\VXMLServer\Tomcat\webapps\ROOT
The above "probe" expression is slightly more accurate as it ensures that you have the CVP VXML web app in place, and not just a Tomcat installed. Not that this would normally be an issue if you've done your install correctly. Another point in favour is that the traffic is smaller as the resulting page is very small.
Geoff
prakashj Sat, 05/23/2009 - 22:08
Hi Amir,
Thanks for your help it is working fine with above mentioned configuraiton.
