ASA logging
May 6th, 2009
Hi all
I need to log any external attack to the ASA. To do this i have issued the folowing commands:
logging enable
logging timestamp
logging buffer-size 100000
logging buffered warnings
access-list acl-out extended deny ip any any log warnings
The problem is that i get some lines in my buffer regarding some denyed external traffic from acl-out but if i perform an online port scaner or try to establish a TCP connection from an unauthorized address i get no lines regarding this.
Anyone can give me some idea?
Thank you
Miquel
nomair_83 Wed, 05/06/2009 - 04:10
check if there is any command where you can call acl-out with logging?
like logging access-list acl-out(assuming)
msantiveri Wed, 05/06/2009 - 06:12
Hi nomair.
There are no options like you kindly suggest. I think that the ACL are already called with the argument "log warnings" in the acl.
Gracias!
I'm trying with logging list qith no success
More ideas?
Thank you very much
