Subnet mask problem
May 6th, 2009
hi Folks,
I have this situation where a customer has this addressing.
The customer has subnetted 192.168.1.0 network as follows.
192.168.1.48/28 and 192.168.1.64/28.
the problem is,now they want to match the IP range of 192.168.1.80 to 192.168.1.254 in an access-list. So my problem is, what subnet mask will match the remaining range of 192.168.1.80 to 192.168.1.254 after the initial /28 subnetting ?
Giuseppe Larosa Wed, 05/06/2009 - 03:55
  • Hall of Fame,
    Founding Member
Hello Yahaya,
being an ACL you can use multiple lines to be able to cover the required address range.
So the answer is multiple ACL lines:
192.168.1.128 0.0.0.127 matches 192.168.1.128-192.168.1.255
192.168.1.80 0.0.0.15 matches 192.168.1.80-192.168.1.95
192.168.1.96 0.0.0.31 matches 192.168.1.96-192.168.127
you need to see every acl line as made of three using the three blocks.
Hope to help
Giuseppe
