Jaime Valencia Wed, 05/06/2009 - 03:52
it's the number you call to reach the hunt list/line group with the VM ports and reach VM
I already replied to your other post, please read the guides for CUCMBE
java
if this helps, please rate
Jaime Valencia Wed, 05/06/2009 - 05:03
1 VM pilot per integration (1 minimum)
VM ports = as many as you're licensed for or you want to use per integration
In CUCMBE is 1 VM pilot and the X amount of VM ports you're licensed for.
please read the documentation
java
