Port -changed state to down - up
Answered Question
May 6th, 2009
We seem to get a lot of these errors since our change over to Cisco.What causes it and why. (Normal pc connected to this port)
Product 3560G
3-Error 5/1/2009 16:09 Interface GigabitEthernet0/12 changed state to down
3-Error 5/1/2009 16:10 Interface GigabitEthernet0/12 changed state to up
3-Error 5/1/2009 16:10 Interface GigabitEthernet0/12 changed state to down
3-Error 5/1/2009 16:11 Interface GigabitEthernet0/12 changed state to down
3-Error 5/1/2009 16:11 Interface GigabitEthernet0/12 changed state to up
3-Error 5/1/2009 16:18 Interface GigabitEthernet0/15 changed state to down
3-Error 5/1/2009 16:18 Interface GigabitEthernet0/15 changed state to up
3-Error 5/6/2009 12:23 Interface GigabitEthernet0/15 changed state to down
3-Error 5/6/2009 12:23 Interface GigabitEthernet0/15 changed state to up
Correct Answer by deepa.muralidharan about 7 years 9 months ago
As mentioned, this kind of any issue generally occurs due to Duplex / speed mismatch.
Check the interface parameters; are there CRC / input errors / output errors / collisions / interface resets etc??? This indicates a physical layer issue.
One of the follwing possibilities may result errors :
1. Duplex / Speed Mismatch
2. Issue with Cabling (between the system & switchport)
3. Bad switch port
4. Bad NIC on the system.
Try solating & fixing the issue.
Even after confirming that all the above parameters are fine, if you see the issue to be continuing, try one of the cnfigurations below:
System Switchport
Auto 100Mb-Full duplex
100Mb-Full duplex Auto
Though the ideal condition is to have both the switchport & system NIC set to 100Mb - Full duplex, sometimes, this doesn't work as expected.
Overall Rating: 5 (1 ratings)
dgroscost Wed, 05/06/2009 - 11:34
Misconfigured duplex/speed settings between switch and host (PC)
Faulty Ethernet cable
PC Issue
I would first check the duplex/speed settings on the NIC on the PC - then match or correct on the Cisco switch.
Leo Laohoo Wed, 05/06/2009 - 13:47
I've seen this issue several times when I'm dealing with legacy NIC's. If the PC's NIC is only a 10/100BaseTx, then configure the switch port to auto negotiate to 10/100 (auto 10 100) or you can hard-code it down to the speed.
Hope this helps.
Correct Answer
deepa.muralidharan Wed, 05/06/2009 - 18:15
3. Bad switch port
System Switchport
