sip trunk down
May 6th, 2009
Hi all,
We have a psenario having ccme conncted to remote end PBX through sip trunk.I can make voip calls from here to remote.I need a solution to reroute the calls through pstn automaticaly if this voip line is down.If anyone having solution for this please help me..any replies will be extremely valuable..
Nicholas Matthews Wed, 05/06/2009 - 04:39
  • Red, 2250 points or more
This is fairly easy. Let's say you have an access code of 9 followed by 10 digits for all calls.
dial-peer voice 1 voip
description to pbx
session protocol sip
destination-pattern 9..........
codec g711ulaw
no vad
dtmf-relay rtp-nte
preference 0 (default)
dial-peer voice 2 pots
port 0/0/0:15
preference 1
If you leave out the preference, these will have the same destination pattern and the gateway will load balance between them by default. By putting a higher preference value on the POTS dial peer it will not be routed to unless the first dial peer fails.
hth,
nick
