HUM logs
May 6th, 2009
sometimes in HUM, I try to load MIBs and they fail dued to dependencies. Today I'm trying to load a MIB related with QoS that depends on other 23 MIBs, and I don't know which is the one that fails.
Are there any log files where I could see this info?
kahjin.khoo Tue, 09/29/2009 - 02:46
Like you I was trying to pinpoint the exact MIB that was lacking to compile CISCO-CLASS-BASED-QOS-MIB.
However I couldn't locate any error related messages pertaining the compilation. Did I miss something?
Btw did you manage to load the said QOS mib above?
cmartinvalle Tue, 09/29/2009 - 02:54
finally I was able to load the MIBs. If dependencies are missing you can find the MIBs needed in NMSROOT/log/upm_base.log.
Also, you can search in for CISCO-CLASS-BASED-QOS-MIB and dependencies are shown.
kahjin.khoo Tue, 09/29/2009 - 03:10
Thanks for replying. I tailed upm_base.log in /var/adm/CSCOpx/log/ and was looking for something like "Error while compiling. Required dump file not available." but I didn't come across anything like that.
Yeah I got the dependency reference from here:
Oddly enough, I had the QOS MIB loaded and working fine in Windows, but no joy for Solaris.
cmartinvalle Tue, 09/29/2009 - 03:19
I installed LMS + HUM in a Windows server...
Perhaps you can you enable some debug in HUM in order to see anything else in a log file.
kahjin.khoo Tue, 09/29/2009 - 22:01
Okay the problem was resolved with some help from Cisco. Things to note:
1. HUM 1.2 was deployed
2. MIB compile errors were found in HUMPortal.log, not upm_base.log for my case.
3. RFC1158-MIB was the missing MIB, and was not listed in the dependency list.
Anonymous (not verified) Tue, 09/29/2009 - 07:24
Anonymous (not verified) Tue, 09/29/2009 - 07:25
Anonymous (not verified) Tue, 09/29/2009 - 16:05
