4th server to CM group
Answered Question
May 6th, 2009
  • Silver, 250 points or more
Don't have more than 3 server in my cluster but I wonder what happen when you try to add 4th server to CM group.
Any error message pop up?
Correct Answer by Rob Huffman about 7 years 10 months ago
Hi Chris,
Very nice example of how to set up CCM Groups! +5 points my friend.
Cheers!
Rob
PS: Konrad, if you try to add a 4th CCM to a Group that already exists with 3 members, an error box will pop up preventing this action :)
Overall Rating: 5 (4 ratings)
chadlincoln Wed, 05/06/2009 - 10:29
  • Bronze, 100 points or more
There should be no problems. Just add the server to the Pub as a node before you install and have the security password ready. Also confirm that your licensing on the pub allows for that additional node.
Please rate if this helped.
Edit: I didn't read the entire problem. You can only have 3 servers in a CM group. I thought you were asking in a cluster.
Jaime Valencia Wed, 05/06/2009 - 10:44
  • Cisco Employee,
  • Hall of Fame,
    2011
that is not correct:
A Cisco Unified Communications Manager Group specifies a prioritized list of up to three Cisco Unified Communications Managers.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmcfg/b02cmgrp.html
I'm not sure if you receive a pop-up or if simply the add arrow greys out, but for sure you cannot add a 4th member
java
if this helps, please rate
Chris Deren Wed, 05/06/2009 - 13:18
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
If you have more than 3 call processing servers you simply structure your groups to provide redundancy/load balances accordingly. I have one 10 node cluster with 8 call processing servers (8 is max) where I did 4 groups as following:
Group1:
Sub1, Sub2, Sub4
Group 2:
Sub3, Sub4, Sub2
Group3:
Sub5, Sub6, Sub8
Group4:
Sub7, Sub8, Sub6
This way you accomplish 1:1 redundancy where the even CMs are backups, and they are also secondary backups to other groups.
HTH,
Chris
KonradStepniewski Wed, 05/06/2009 - 23:03
Could you try to add 4th server to new Group5? I wonder what happen.
Thanks for nice redundancy example.
Chris Deren Thu, 05/07/2009 - 05:35
  • Hall of Fame,
Not sure what you mean, I have 8 servers wich is the max distributed between 4 groups. You can create more groups if you want your deisgn to be different, but you can only have 3 CMs in a single group, CM will not let you add more.
HTH, Please rate all posts!
Chris
Correct Answer
Rob Huffman Thu, 05/07/2009 - 05:47
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi Chris,
Cheers!
Rob
Chris Deren Thu, 05/07/2009 - 05:51
  • Hall of Fame,
It will prevent it, it will not let you save and and give you the following error message:
" Update failed. A Cisco CallManager Group may not contain more than 3 Cisco CallManagers"
HTH,
Chris
