setting up corlist
Answered Question
May 6th, 2009
hi guys,
i have question regarding corlist setup. can we setup this based on the ephone-dn instead of ephone. for example, there are 2 offices, office A has extension 100 and 101 and the phone number is 111-2222. then office B has extension 200 and 201 and the phone number is 333-4444. is there a way from the phone that if someone picks either extension then the it only uses specific outgoing number?
does this make sense?
thank you
Correct Answer by Marcos Hernandez about 7 years 8 months ago
It is possible. Something like this:
!<br/>dial-peer cor custom<br/> name office-a<br/> name office-b<br/>!<br/>dial-peer cor list call-office-a<br/> member office-a<br/>!<br/>dial-peer cor list call-office-b<br/> member office-b<br/>!<br/>!<br/>dial-peer voice 20 pots<br/> description 111-2222<br/> corlist outgoing call-office-a<br/>!<br/>dial-peer voice 30 pots<br/> description 333-4444<br/> corlist outgoing call-office-b<br/>!<br/>!<br/>ephone-dn 1<br/> corlist incoming call-office-a<br/>!<br/>ephone-dn 2<br/> corlist incoming call-office-b<br/>!<br/>
If you are using the CCA config, it gets a little more complicated, since you have to work with existing COR lists, but the idea is the same. Hope this helps.
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
Overall Rating: 5 (1 ratings)
Correct Answer
Marcos Hernandez Wed, 05/06/2009 - 07:19
Marcos Hernandez
Cisco Systems, Inc.
