Collin Clark Wed, 05/06/2009 - 08:30
  • Purple, 4500 points or more
You need to "move" the show commands to another privilege level then assign the user to that level.
jtalbaugh Wed, 05/06/2009 - 09:29
For example:
Router(config)#privilege exec level 4 sh run
Router(config)#username cisco privilege 4 password cisco
Enable level is level 15.
You can create a new user with a level lower than that.
Then you will need to associate the show commands to the appropriate level.
Keep in mind that the sh run output might not show everything, because each command shown in the config would need to be authorized for the restricted user to see it.
