sip-ua authentication to Telia in Sweden
Answered Question
May 6th, 2009
Have anyone configured a SIP Trunk to Telia on CME 7.1?
This is what Telia THINK the sip-ua shall look like.
Config:
sip-ua
authentication username 00000000 password xxxxxxxxxxx
no remote-party-id
retry invite 2
retry register 3
timers connect 100
registrar dns:telia.com expires 3600
sip-server dns:telia.com
host-registrar
Some how it will not register. When I use X-Lite client on my PC from CounterPath I get the SIP Trunk up and running and can do calls, same username and password so the SIP Trunk is working but not on Cisco 2811 with CME 7.1
Her is the debug:
May 6 10:18:29.269: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event
: ccsip_spi_get_msg_type returned: 3 for event 7
May 6 10:18:29.273: //14/F0EE245B8025/SIP/Info/sipSPIIcpifUpdate: CallState: 2
Playout: 0 DiscTime:263596 ConnTime 0
May 6 10:18:29.273: //14/F0EE245B8025/SIP/State/sipSPIChangeState: 0x4A41D134 :
State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DEAD, SUBSTAT
E_NONE)
May 6 10:18:29.273: //14/F0EE245B8025/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4A41D134
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 055555555
Called Number : 004791300000
Source IP Address (Sig ): 200.200.200.100
Destn SIP Req Addr:Port : :5060
Destn SIP Resp Addr:Port : :5060
Destination Name : telia.com
Disconnect Cause (CC) : 3
Disconnect Cause (SIP) : 200
May 6 10:18:29.273: //14/F0EE245B8025/SIP/Info/sipSPIUdeleteccCallIdFromTable:
Removing call id E
May 6 10:18:29.273: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Co
ntext for key=[6] removed.
May 6 10:18:29.273: //14/F0EE245B8025/SIP/Info/sipSPIUdeleteCcbFromUACTable: **
**Deleting from UAC table.
May 6 10:18:29.273: //14/F0EE245B8025/SIP/Info/sipSPIUdeleteCcbFromTable: Delet
ing from table. ccb=0x4A41D134 [email protected]
181
May 6 10:18:29.273: //14/F0EE245B8025/SIP/Info/sipSPIFlushEventBufferQueue: The
re are 0 events on the internal queue that are going to be free'd
May 6 10:18:29.273: //14/F0EE245B8025/SIP/Info/ccsip_qos_cleanup: Entry
May 6 10:18:29.273: //14/F0EE245B8025/SIP/Info/sipSPI_ipip_free_codec_profile:
Codec Profiles Freed
May 6 10:18:29.273: //14/F0EE245B8025/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4
A41D134
May 6 10:18:29.273: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO co
ntext for key[6]
Correct Answer by chadlincoln about 7 years 9 months ago
Post the output for "show sip-ua reg stat"
If the telco is expecting you to register your main number, you'll have that under an ephone-dn. For example, if they want to see registered 555-555-5555, you'd put this:
ephone-dn
number 5555555555
Then run the "sh sip-ua reg stat" command again and you should at least see the number trying to register.
Please rate if this helped.
Overall Rating: 0 (1 ratings)
Nicholas Matthews Wed, 05/06/2009 - 09:23
These debugs aren't helpful without their context. They describe the events of a sip message (and conversation) that aren't referenced.
-nick
Correct Answer
chadlincoln Wed, 05/06/2009 - 19:26
ephone-dn
number 5555555555
