Enable WPA on a Autonomous 1252AG
May 6th, 2009
bandwidth drops from 270Mpbs to 48Mbps when WPA is enabled. Is there a work around? Thanks
gamccall Wed, 05/06/2009 - 11:29
Yes: The workaround is to use WPA2 rather than WPA.
The AP cannot offer N datarates if TKIP or WEP encryption is enabled. The only supported encryption modes for N rate are AES or no encryption.
Trending Topics - Security & Network
