Maximum throughput of a 2821
May 6th, 2009
If only using the embedded GIG-E interfaces in a 2821 router, what is the maximum throughput that can be achieved? Will it support true line rate in a LAN only environment?
JB
Overall Rating: 5 (4 ratings)
iyde Wed, 05/06/2009 - 12:12
Hi Jon.
Do you have an URL for where Cisco updates these performance sheets?
Thnx, Ingolf
Joseph W. Doherty Wed, 05/06/2009 - 12:23
For line rate gig Ethernet, minimum size packets, you need 1.488 Mpps (double for duplex). The 2821's (best) 170 Kpps falls very short.
When looking at the performance sheet Jon provided, keep in the need to allow processing for other services and a ample cushion. (For example, don't plan on exceeding 50% average utilization.) Don't forget to allow for duplex bandwidth. As a rough rule of thumb, you might want to not exceed 25% of the Fast/CEF Switching bandwidth as documented on the reference sheet.
bergeron33 Wed, 05/06/2009 - 12:33
All - Can't thank you enough for the replies and informative answer to my question.
JB
dreamin41 Thu, 03/31/2011 - 14:58
Hey Guys,
I see this post is quite old, but I came across it while doing some thoughput tests on a Cisco 2821. I'm a little confused about the difference between the Router Performance sheet and the results I'm coming up with.
I'm currently looping my Ixia Packet generator through a bone-dry 2821 and I'm receiving about 260M througput using an HTTP test:
GigabitEthernet0/2 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is c84c.7538.0242 (bia c84c.7538.0242)
  Internet address is 10.69.255.254/16
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 66/255, rxload 4/255
  Keepalive not set
  Full Duplex, 1Gbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 23
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 19453000 bits/sec, 36505 packets/sec
  30 second output rate 261191000 bits/sec, 72698 packets/sec
     92802685 packets input, 2984776442 bytes, 0 no buffer
     Received 6776 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     142027515 packets output, 1121519489 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     24 lost carrier, 0 no carrier, 0 pause output
My test configuraiton consists of a client and server where the client is sending up to 300,000 TCP SYN's to the server. The client is receiving 1024 byte frames from the server.
There are two things I don't understand:
First off, why does the Performance sheet list the PPS as 170Kpps when I'm showing a far greater througput rate at only roughly 70Kpps?
Secondly, these connections are between two GIGE interfaces on the 2821. Are these normal throughput rates for this configuration?
I've attached a screen shot from the Ixload client for another view.
Joseph W. Doherty Fri, 03/27/2015 - 12:37
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Because the performance sheet references 64 byte packet sizes.  Yours are larger, correct?
Also, on many routers, their PPS rate drops as the packet size increases.  Yet, the overall throughput is usually higher even at the lower PPS rate (which is likely what you're seeing.)
Likely it is, although it might not be so documented by Cisco.
Cisco published a later whitepaper (attached), documenting the performance of later ISRs under different conditions.  What's interesting is to study the difference in performance between ISRs and even on the same ISR, in different usage roles.  It confirms a statement found on the performance sheet you're looking at, which is "Every situation is different - please simulate the true environment to get applicable performance values.".
