05-06-2009 11:58 AM
So I created a couple of flows using the Wizard in FM (3.3.1(c)) and they show up in Fabric Manager web client etc. How do I get rid of them. I don't need them anymore. All the doco I can find shows me how to run the wizard, nothing on how to remove them.
Solved! Go to Solution.
05-11-2009 01:44 PM
Remove them manually in Conft mode use "no flow" commands, use the wizard to create new flows and ticking the box, delete old-flows.
Alternatively (probably what you want), enter FabricManager.
Select fabric tree, go to the Flow_Statistics tree entry (on the switches tree at bottom).
On the right the flows will show up and delete wanted flows by selecting them and clicking the small (red-arrow) remove icon.
Goodluck,
Peter.
05-11-2009 01:44 PM
Goodluck,
Peter.
05-12-2009 04:51 AM
Excellent!! I was trying to figure it out via the cli but I was looking for flows not fcflows. CLI works if you know which switch and module you're looking for. Otherwise the GUI is nice for mass deletes.
