Load Balancing Router 1811
May 6th, 2009
I have a Cisco 1811 with two WAN connections. I am using Track to detect down state of principal WAN interface. Everything works fine and the backup line will be up as soon as the principal line goes down.
The problem that I have is that, even when the principal line is up and running, I have data transfer on the backup interface! This data transfer costs money, because the data transfer on backup line is limited.
How can I prevent this data transfer when the first line is up?
Mehdi
Overall Rating: 5 (1 ratings)
Edison Ortiz Wed, 05/06/2009 - 12:11
Please post config and the routing table output to determine what routes may be preferred via the backup connection.
You can potentially have a problem as routes coming into your network via the backup connection, not leaving your network. In that case, you need to troubleshoot the remote device for routing preference.
__
Edison.
Mehdi Talei Wed, 05/06/2009 - 12:39
ip sla 10
icmp-echo xxx.xxx.xxx.xxx source-interface FastEthernet0
timeout 4000
threshold 10
frequency 4
ip sla schedule 10 life forever start-time now
ip address dhcp client-id FastEthernet0
no ip redirects
no ip unreachables
ip nat outside
ip virtual-reassembly
no ip route-cache cef
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
no cdp enable
crypto ipsec client ezvpn NAME
interface FastEthernet1
ip address dhcp client-id FastEthernet1
no ip redirects
no ip unreachables
ip nat outside
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
no cdp enable
crypto ipsec client ezvpn BACKUP
ip route 0.0.0.0 0.0.0.0 FastEthernet0 track 1
ip route xxx.xxx.xxx.xxx 255.255.255.255 FastEthernet0
ip route 0.0.0.0 0.0.0.0 FastEthernet1 dhcp 10
sh ip int br
FastEthernet0 AAA.BBB.CCC.DDD YES DHCP up up
FastEthernet1 EEE.FFF.GGG.HHH YES DHCP up up
sh ip route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
xxx.0.0.0/32 is subnetted, 1 subnets
S xxx.xxx.xxx.xxx is directly connected, FastEthernet0
AAA.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
S yyy.yyy.yyy.yyy/32 [254/0] via AAA.BBB.CCC.1, FastEthernet0
C AAA.BBB.CCC.0/24 is directly connected, FastEthernet0
10.0.0.0/25 is subnetted, 1 subnets
C 10.132.29.0 is directly connected, Vlan1
EEE.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C EEE.FFF.GGG.0/24 is directly connected, FastEthernet1
S EEE.FFF.GGG.HHH/32 [254/0] via EEE.FFF.GGG.HHH, FastEthernet1
S* 0.0.0.0/0 is directly connected, FastEthernet0
Fa0 is the principal line and Fa1 is the backup one.
Edison Ortiz Wed, 05/06/2009 - 12:49
There isn't any routes pointing Fa1 other than the peer route /32 and the /24 from the subnet.
It's odd the subnet on that interface is /24 instead of /30. Perhaps broadcast traffic from the remote /24 is being sent/recvd on this interface hence causing some traffic over this link.
You also have a dhcp client running on the interface so some packets will be transmitted over this link.
If you want to determine what kind of traffic is entering/leaving the interface, I recommend configuring NetFlow.
http://www.cisco.com/en/US/docs/ios/netflow/configuration/guide/cfg_nflow_data_expt_ps6350_TSD_Products_Configuration_Guide_Chapter.html
__
Edison.
Mehdi Talei Wed, 05/06/2009 - 12:55
Edison,
Thanks a lot for the reply.
Yes, the traffic should be verified to see where is it coming from.
My another question was how to monitor the traffic on WAN interface that you answered by your suggestion using Netflow.
I will do it and will let you know the result.
Thanks.
Mehdi Talei Thu, 05/07/2009 - 06:23
Edison,
I configured Netflow on my backup interface, but nothing appears when I do sh ip cache flow. Here is the result:
sh ip cache flow
IP packet size distribution (0 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
IP Flow Switching Cache, 278544 bytes
0 active, 4096 inactive, 0 added
0 ager polls, 0 flow alloc failures
Active flows timeout in 30 minutes
Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 34056 bytes
0 active, 1024 inactive, 0 added, 0 added to flow
0 alloc failures, 0 force free
1 chunk, 1 chunk added
last clearing of statistics never
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
SrcIf SrcIPaddress DstIf DstIPaddress Pr SrcP DstP Pkts
I configured simply ip flow ingress and
ip flow egress under interface Fa1.
Am I missing something?
PS : I configured netflow on Fa0 as well, but still nothing appears. I believe that I am doing something wrong, but I don't know what it is!!!
Edison Ortiz Thu, 05/07/2009 - 06:46
You need to enable mroute-cache, route-cache and route-cache cef on the interfaces.
I'm not sure why you are disabling those features since they help on the router performance. Disabling those features cause the traffic to be process-switched instead of cef-switched.
HTH,
__
Edison.
Mehdi Talei Thu, 05/07/2009 - 06:53
I had enabled them, but still getting nothing on Fa1.
I get the flow on Fa0 (the principal line) though.
Mehdi
Edison Ortiz Thu, 05/07/2009 - 06:57
Good, it seems Fa1 traffic flow isn't constant.
Do you see input/output increasing on the interface and the NetFlow counter isn't showing anything? If so, it can be the router's control traffic like keepalive, dhcp client - among other things.
I also noticed you have a crypto session on the interface, is that session active the whole time?
__
Edison.
Mehdi Talei Thu, 05/07/2009 - 10:20
input/output are increasing non-stop on the interface. Netflow counter is increasing also. But they seem to be irrelevant according to the two following results :
sh int fa1:
9 packets input, 570 bytes
Received 4 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
180 packets output, 10800 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier
sh ip cache flow
IP packet size distribution (4 total packets):
.000 1.00 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
1 active, 4095 inactive, 4 added
58 ager polls, 0 flow alloc failures
1 chunk, 0 chunks added
last clearing of statistics 00:24:23
TCP-other 3 0.0 1 52 0.0 0.0 15.2
Total: 3 0.0 1 52 0.0 0.0 15.2
Fa1 74.198.AAA.BBB Local 74.198.CCC.DDD 06 CEBC 01BD 1
(IP address 74.198.CCC.DDD is the one on my interface)
In Netflow the traffic which is showed is ingress one, but on the interface is the packets output which are increasing.
I do agree with you about router control traffic. This traffic might be that, but i need to eliminate them though.
The crypto session will stay inactive until when the interface comes up. I even removed it from the interface, but the result is the same!
dgroscost Wed, 05/06/2009 - 12:11
Simplest way - Use floating static routes.
ISP1 - Preferred path - say your default route is 10.10.10.1.
ISP2 - Backup route, costs $ - say your default route is 20.20.20.1
Change your routes to:
ip route 0.0.0.0 0.0.0.0 10.10.10.1 10
ip route 0.0.0.0 0.0.0.0 20.20.20.1 20
This way all traffic will route over ISP#1 until that route disappears from the routing table (link goes down), then traffic will route over ISP #2.
You could still use the track functionality in those statements if you want - just attach a 'track tracking#' to the end of the route statements.
Be sure to remove any other route statements in there that were previously used.
pkurdziel Wed, 05/06/2009 - 12:39
You have a few options.
post your config.
Are you using a routing protocol or static routes?
