6513 is not intergrating with ACS
gaboughanem
hello ,
i have a problem with one of the devices,6513 switch. the acs server is directly connected to the switch inside fwsm.
i am able to ping the ACS server from MSFC and inside FWSM , but it not taking the ACS. i have other 6513 and many other switches and router that integrated normally with ACS.
Please i need some help.
Jagdeep Gambhir
Level 10
Level 10
Incase you are using tacacs and issue " ip tacacs source interface command "
User the interface which is listed in acs network configuration --->switch--->IP address
Switch should use that IP address as source for tacacs packets
~JG
Do rate helpful posts
Jagdeep Gambhir
Level 10
Level 10
~JG
Thank you JG, that was very helpful.
George
