WiSM Redundancy in Campus Network L3 Access
May 6th, 2009
Hi guys,
I'm designing a Campus network L3 Access in a Building with 30 floors and aproximately 250 APs,8 APs in each floor.
For each floor I will use two /24 subnet (one for data and one for voice). I have 2 WiSM...
I don't wanna to use another two /24 subnet for each floor only for redundancy, so I want to know
if i can use the following idea (Please take a look in the PPT File)
I will create a AP Group in each controller to include the APs for each 2 floors (for example floor 1 and 2).
The only diference between those AP Group in each controller is the network subnet associated with the Dynamic
Interface. The AP Group in controller WiSM1-A will be associated with the 192.168.1.0 network and the AP Group
in controller WiSM2-A will be associated with the 192.168.2.0 network.
The APs in the first floor I will configure to use the controller WiSM1-A as primary and I expect to see the hosts with the 192.168.1.0/24 network.
The APs in the second floor I will configure to use the controller WiSM2-A as primary and I expect to see he hosts with the 192.168.2.0/24 network.
If one of those controllers fail (for example WiSM1-A), I think all the APs will use the another controller and I expect to see the hosts with the 192.168.2.0. In this case I know that network 192.168.2.0 is used for both the two floors, not more just one floor. I accept that half the users can use the wireless network during the fail..
Is this works and if yes, can I use this idea with Mobility Group, Roaming L3, etc ????
Thanks in Advanced,
Andre Lomonaco
Overall Rating: 4 (3 ratings)
George Stefanick Wed, 05/06/2009 - 19:31
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Specific to AP group (thinking out loud) If you configure the SAME AP groups in both contollers and when you configure the AP to either AP group. When the AP joins the back up controller i would think it would retain the AP group.
All considering of course if you config the dynamic interfaces.
Bummer i just blew away my test controller that i was ding an AP group lab on ... I could have tested it for you ...
George Stefanick Wed, 05/06/2009 - 19:34
btw... if you go to www.my80211.com (under cisco labs) I did a video on AP group ... you may find it of some interest ..
gamccall Thu, 05/07/2009 - 05:14
  • Silver, 250 points or more
Why not set it up this way?
Floor 1 APs in AP group "FL1", Floor 2 APs in AP group "FL2"
WiAM1-A: group FL1 primary, mapped to 192.168.1; group FL2 secondary, mapped to 192.168.2
WiSM1-B: group FL1 secondary, mapped to 192.168.1; group FL2 primary, mapped to 192.168.2.
This lets you fail over without losing any capacity or functionality.
lomonaco Thu, 05/07/2009 - 06:56
Hi gamccall,
First thanks for your reply...
I like you idea but initially I can't use it cause I put each wism in a ospf tottaly stub area and I use area summarization to have less networks in the core routers....
In my designing, the wism1 is in the
range 10.0.0.0 -> 10.0.95.0 and the
wism2 is in the range 10.0.96.0 ->
10.0.191.0
My Best Regards,
Andre Lomonaco
