How to manage two 6500 in VSS without CiscoWorks
Answered Question
May 6th, 2009
We configured two 6500 with VSS and it's working well, but my customer has HP OpenView and would like to see two 6500 nodes on his map. In reality he would like that each 6500 has one IP address (one ip address for each 6500 like a loopback IP address for example).
Is it possible ?
Correct Answer by jpoplawski about 8 years 3 weeks ago
Just spit balling here, but couldn't you assign an IP address to one port on each chassis.
For example
int Gi1/1/1
Des Chassis One
no switchport
ip add 1.1.1.1 255.255.255.0
int Gi 2/1/1
Des Chassis Two
No switchport
ip add 1.1.2.1 255.255.255.0
Enable some form of routing, ping each respective interface and off to the races you go. In production, I've seen monitoring of SNMP on links with e-mail alert should the VSS trunk go down.
Hope this helps, rate if it does!
JB
Overall Rating: 5 (1 ratings)
fsebera Thu, 05/07/2009 - 10:07
  • Bronze, 100 points or more
My understanding is that when you combine two devices into one via VSS OR when you use stackable switches (3750 series) ONLY a single management address is available for the entire stack.
And from what I have read, (working on the actual setup as we type) a single device is correct.
Frank
iyde Thu, 05/07/2009 - 10:08
  • Silver, 250 points or more
As the VSS makes the two Cat6500 look like one, with one active and one standby Supervisor, it will be my best guess that you cannot do what you want. There's only one Sup active at a time, having the responsibility for both chassis.
mauricio.rodriguez Thu, 05/07/2009 - 12:15
Yes, you have right, in a VSS design there is only one Sup card in active mode for the two cat6500. My problem is how I know when one Cat6500 become down ?
I would like to view the two Cat6500 on a HP OpenView map with two node, when one cat 6500 becomes down I would like to see on the map only one Cat6500 in red. The problem is that all Network Management tools like HP-OpenView uses ping to determine if a node is reachable or unreachable. So, is it possible to configure one different IP address on each cat6500 or someone has an another idea ?
Thanks by advance
iyde Thu, 05/07/2009 - 13:33
As the processor for the whole VSS (both chassis) is the active CPU, all definitions of IP addresses will be on the active supervisor. In other words, no possibility to put an IP address on a chassis.
You will have to rely on syslogs, snmp traps etc. in order to gain info about switc down.
Correct Answer
jpoplawski Fri, 05/08/2009 - 08:01
For example
int Gi1/1/1
Des Chassis One
no switchport
int Gi 2/1/1
Des Chassis Two
No switchport
JB
