Frame Relay + Ripv2 Issue
May 6th, 2009
Hello all,
I am having an issue with frame relay and rip. For some reason I cannot send pings to R3 over frame relay. Here are my configs
Here are the configs for R1
router rip
version 2
redistribute connected
passive-interface FastEthernet0/1
network 10.0.0.0
network 172.16.0.0
default-information originate
no auto-summary
interface Serial0/0/1
ip address 172.16.0.9 255.255.255.252
encapsulation frame-relay
frame-relay map ip 172.16.0.10 103 broadcast
frame-relay interface-dlci 103
frame-relay lmi-type ansi
no keepalive
Configs for R3
interface Serial0/0/0
ip address 172.16.0.10 255.255.255.252
frame-relay map ip 172.16.0.9 301 broadcast
frame-relay interface-dlci 301
no keepalive
clock rate 4000000
router rip
version 2
network 10.0.0.0
network 172.16.0.0
no auto-summary
I was told that there was supposed to be 7 entries for RIP, but I am not sure what I am missing. Can any of you point me in the right direction please?
Overall Rating: 4 (3 ratings)
Giuseppe Larosa Thu, 05/07/2009 - 04:50
Hello Joshua,
I would remove frame-relay interface-dlci XX commands they are good for point-to-point subinterfaces and you are using the main interfaces.
Notice that if the two are directy connected to each other (I see you have the clock on one side) the DLCI cannot change and one of the two should use
frame-relay intf-type dce
Hope to help
Giuseppe
jrosetta1 Thu, 05/07/2009 - 20:34
so your saying my frame relay dcli 103 and 301 commands should not be in there?
Does it matter which two use
frame-relay intf-type dce ?
also what does that command do?
jrosetta1 Thu, 05/07/2009 - 20:52
I tried entering that command and in the packet tracer file it says the command is unreconized
jrosetta1 Thu, 05/07/2009 - 21:37
I can upload the packet tracer file that I been practicing on
jimmysands73_2 Thu, 05/07/2009 - 22:04
Packet Tracer does not handle alot of Frame relay commands. You can use the 'cloud', but as for commands like frame-reley switching and other commands, it wont work for that.
jrosetta1 Thu, 05/07/2009 - 22:17
ic ic.
Right now there is not frame relay switching going on. Its just two serial links (its part of a lab I am testing out).
jimmysands73_2 Fri, 05/08/2009 - 11:55
I plugged in your config and troubleshot it for about an hour, no good....the output below shows it 'should' work...but sometimes with PacketTracer you have to be careful, you could be doing everything right, but PT will say your wrong...I will plug the configs into a lab enviroment Monday or Tuesday and let you know how it goes then.
R1#sh frame-relay map
Serial1/0 (up): ip 172.16.0.10 dlci 103, static, broadcast, CISCO, status defined, active
Serial1/0 (up): ip 172.16.0.9 dlci 103, static, CISCO, status defined, active
R1#sh frame-relay pvc
PVC Statistics for interface Serial1/0 (Frame Relay DTE)
DLCI = 103, DLCI USAGE = LOCAL, PVC STATUS = STATIC, INTERFACE = Serial1/0
input pkts 14055 output pkts 32795 in bytes 1096228
out bytes 6216155 dropped pkts 0 in FECN pkts 0
in BECN pkts 0 out FECN pkts 0 out BECN pkts 0
in DE pkts 0 out DE pkts 0
out bcast pkts 32795 out bcast bytes 6216155
R1#ping 172.16.0.9
Sending 5, 100-byte ICMP Echos to 172.16.0.9, timeout is 2 seconds:
jimmysands73_2 Fri, 05/08/2009 - 17:59
I started a new thread:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&topicID=.ee71a06&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd2fe59
I never could get it working (on real routers), so I am only left to believe it cant. Did you lab say it should work? Was it a cisco netacad lab?
jimmysands73_2 Sun, 05/10/2009 - 07:07
This got solved by another member in the thread listed above. It wasnt an issue with Packet Tracer, but more so an error in logic between my keyboard and the seat of my chair :P
jrosetta1 Sun, 05/10/2009 - 07:50
It was a cisco netacad lab. I will check out the thread you linked above.
thx for all your help!
jimmysands73_2 Sun, 05/10/2009 - 08:06
Dont get too caught up in getting this to work, as I understand it in the real world you would have a dedicated FR Switch, not a router mimicking one. PT still didnt take the no frame-relay inverse arp, but I got the config below working in the on real 2811s.
Here are my configs:
For one:
interface Serial0/0
no keepalive
no fair-queue
clock rate 64000
frame-relay map ip 172.16.0.9 103 broadcast
no frame-relay inverse-arp
end
For the other:
Current configuration : 216 bytes
interface Serial0/1
no keepalive
end
jrosetta1 Sun, 05/10/2009 - 14:47
I appreciate all the help. I understand that in this lab we do not have a frame relay switch (in the other labs we did have one).
Ya no frame relay inverse-arp does not work on PT (not sure if it works in Packet Tracer 5.1).
the no fair-queue whats that? I never used that command. Other than that I have similar commands entered on the PT routers.
I wonder if the frame relay inverse arp is whats keeping Packet tracer from completing it all?
