wrvs4400n VPN setup
Answered Question
I've got a wrvs4400n with the intent to enable VPN access to my home computer instead of simple RDP via port forwarding.  However I can't figure out how to setup the wrvs4400n VPN.  I don't think I need a tunnel as the connection from my laptop will be from different locations depending on where I'm traveling to.  My home network has a dynamic IP, but I do have it setup with dyndns.org, so i know the IP all the time.  I did hope this will be a simple task, but as it turns out I'm dead in the water...  Any advise and support would be greatly appreciated.
Correct Answer by Te-Kai Liu about 7 years 11 months ago
If you contact Cisco Support, someone should be able to get the QuickVPN working for you. Some common issues I have seen include:
- WRVS4400N is behind a NAT device
- QuickVPN client is in a hot spot that does not allow IPsec traffic
- QuickVPN client does not use the default Port, which is Auto, for connecting with the remote QuickVPN router
- QuickVPN client is in the same IP subnet as the remote network, e.g. both in the 192.168.1.x network
- some network card has hardware acceleration that breaks the checksum of ipsec packets generated by the Windows OS running the QuickVPN client.
- etc.
I am having the same issue, VPN is not working for me. I am getting the failed to establish connection error. I followed these instructions you provided to start and other troubleshooting methods. I disabled firewall on the computer running quickvpn and it still won't connect to the VPN router in the office from the internet. What are the settings that I need to look at to try to get this to work? Any certain settings on the router/computer that I need to enable/disable? Could it be that the router is faulty and I need to RMA it?
Thank You,
The attached should help you get started in using QuickVPN Client, which can connect to your WRVS4400N at home from the internet.
Overall Rating: 5 (3 ratings)
Correct Answer
Te-Kai Liu Sun, 05/10/2009 - 16:47
  • Gold, 750 points or more
Correct Answer
Thank You,
Correct Answer
Te-Kai Liu Tue, 05/19/2009 - 15:32
- etc.
Related Content
