CUE AA transfer problems
May 6th, 2009
we use the number2name-anidnis.tcl script from Paolo with the AutoAttendant Menü
on CUE.
Our Problem:
Someone dials the AA number and select for example the two (this is a voice-hunt group or a single number),
then the call disconnet.
Without the the AA Menü we have no Problems with number2name, and without the number2name script we have
no Problems with the transfer.
System: ccme vERSION 7.0(0)
IOS: Version 12.4(20)T
CUE: Cisco Unity Express Version 3.2
The Konfig:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
dial-peer voice 1 pots
description ** Amt rein **
service num2name
incoming called-number .T
direct-inward-dial
dial-peer voice 550 voip
description **AutoAttendant CUE **
destination-pattern 550
session protocol sipv2
session target ipv4:10.1.0.6
dtmf-relay sip-notify
codec g711ulaw
no vad
SIP Gateway: 10.1.0.3
SIP Port Number: 5060
DTMF Relay: sip-notify,sub-notify
MWI Notification: outcall
MWI Envelope Info: disabled
Transfer Mode: bye-also
SIP RFC Compliance: Pre-RFC3261
tstanik Thu, 05/14/2009 - 06:15
  • Bronze, 100 points or more
CUE is configured to use BYE-Also for transfers. Maybe the CME TCL scripts don't work with the SIP Also header field. You might want to try the other CUE settings, e.g.
ccn subsystem sip
transfer-mode semi-attended
At least if the transfer fails this should allow CUE to recover the initial call.
leahpaR_79 Thu, 05/28/2009 - 22:51
we have change the script and everything is fine :-)
