DEVICE_TARGET_ABORT_IND message received from Peripheral(5000)
May 6th, 2009
Agent is going to reserve state when call arrives and calls is disconnecting.
CSS/partition are there
We have a setup with follwing components...
icm - 7.2 (duplexed)
cucm - 6.1 ( cluster of 3, 1 pub & 2 sub )
cVP - 7.0 (load balancing)
prakashj Wed, 05/06/2009 - 22:50
The following error i got from CVP
17:22:46 Trace: DEVICE_TARGET_ABORT_IND message received from Peripheral(5000) CRSCallID(Date 149144 ,ID 696), NetworkTarget(5000),MRDomain(1), Agent(5009).
17:23:46 Trace: DEVICE_TARGET_ABORT_IND message received from Peripheral(5000) CRSCallID(Date 149144
prakashj Wed, 05/06/2009 - 22:51
sorry earlier message was from ICM and the below error from CVP
7:12:29 Trace: 00000012: CALLFLOW: IP transfer - Agent hung up : DNIS = 7001234567152 : GUID = 2F9064F80304001F20345DD2A3A0591F : CID = 9FE79F26397F11DE83D10022915807EC
17:12:29 Trace: 00000012: CALLFLOW: Call ended : DNIS = 7001234567152 : GUID = 2F9064F80304001F20345DD2A3A0591F : CID = 9FE79F26397F11DE83D10022915807EC
17:12:29 Trace: 00000011: CALLFLOW: Call successfully established (slow start) : DNIS = 8881 : CID = 9FE79F26397F11DE83D10022915807EC
17:12:31 Trace: 00000011: CALLFLOW: Disconnecting caller because agent hung up. : DNIS = 8881 : CID =
csshenoy80 Wed, 05/06/2009 - 23:32
The error seems to be when the CVP is trying to transfer the call to the IP Phones, the CVP is not able to reach the partition of the CUCM IP Phones.
Check the Call Search Spaces.
Does your setup include Gatekeeper.
