compatibility ASA-877
May 7th, 2009
I was wondering if there is any compatibility issue if an ASA5510 firewall is configured as an EZVPN server and a 877adsl router configured as a ezvpn remote.. i have configured it and find only software clients can connect. but the 877hardware client connot. any inputs?
Verify your ISAKMP configuration. Once you configure both devices, the Cisco 877 router attempts to setup the VPN tunnel by contacting ASA automatically using the peer IP address. After the initial ISAKMP parameters are exchanged, the router displays this message:
Pending XAuth Request, Please enter the
following command: crypto ipsec client ezvpn xauth
