SNMP lightweight access point connected to 4400
Answered Question
May 7th, 2009
I am trying to monitor 1250 ap's directly via snmp. Is it possible to consolidate the SNMP MIB of the 1250 ap's who are connected to 4400 controller running R 5.2.
I am wondering if it's possible to monitor access points directly (not via wcs or controller) via snmp?
Regards, Wim
Correct Answer by ericgarnel about 7 years 11 months ago
No it is not. You have to pull the snmp values from the controller. There are controller templates for Cacti network monitoring system that pull lots of info
Overall Rating: 4.5 (2 ratings)
Correct Answer
ericgarnel Thu, 05/07/2009 - 05:18
  • Gold, 750 points or more
Pushkar Sambhoos Thu, 05/07/2009 - 08:27
  • Cisco Employee,
If the AP is in LWAPP mode, you cannot directly poll the AP using SNMP. You have to poll the controller to get all the information about the AP. You can download the MIBs for controller v5.2 form the URL below.
http://tools.cisco.com/support/downloads/go/InterfaceModuleSWT.x?mdfid=279911269&mdfLevel=Model&treeName=Wireless&modelName=Cisco%204404%20Wireless%20LAN%20Controller&treeMdfId=278875243
Pushkar
wleppens82 Fri, 05/08/2009 - 01:51
Hi Pushkar,
Thanks a lot for the information. It's very helpfull. I suppose you need to deploy this in cooperation with an HPoV (as an example). Do you know where i can find more information in-depth about implementing this?
Thanks, WIm
mplaksin0 Wed, 12/29/2010 - 07:44
Eric, i am looking for something like you told in forum.
How i can get the oid to that metrics?
pioneerinvestments Thu, 03/06/2014 - 09:36
This is actually possible and the APs will respond to the SNMP queries if you add the community.  You just can't write it to memory, so when the APs reload after say an upgrade, you'll lose it all.  Potentially you could have a Config Management script which runs each night and adds the snmp-server config to the APs each night, so if they have rebooted and lost the config again, they'll get it again shortly there after.
Trending Topics - Security & Network
