eigrp and ospf on NBMA
May 7th, 2009
Hi all
when using protocols such as eigrp and ospf on frame relay environments etc, do you have to use the neighbour command?, and do I just need to add all the neighbours that should be reached uder the router ospf command ? is this also the same for eigrp ? OR when using the broadcast command, d i not need to put the neighbours in as the multicast will be replicated to all circuits ?
