New IVR zone
Answered Question
May 7th, 2009
We already have four IVR Zones in our Zoneset and I need to add two new Zones. Should I edit the Zone database and add the two new Zones or run the Wizard and follow the idoit proof steps? I'm happy to add/remove devices in the non-IVR setup but just wanted to know of any gotcha's in IVR world?
Thanks.
Correct Answer by Michael Brown about 7 years 9 months ago
Either way, just make sure you are making the changes to the VSAN zoneset or the IVR zoneset on a switch that has IVR enabled.
MDS1---MDS2---MDS3
VSAN1 IVR VSAN2
IVR is only enabled on MDS2 to IVR VSAN1 and VSAN2.
Make changes to VSAN1 local zoneset on MDS2.
Make changes to VSAN2 local zoneset on MDS2
Make changes to IVR zoneset on MDS2
The gotcha is that any zone change must be made on the IVR enabled switch, even if the change is only to the local zoneset.
Hope this helps,
Mike
Overall Rating: 4 (1 ratings)
Correct Answer
Michael Brown Thu, 05/07/2009 - 02:23
MDS1---MDS2---MDS3
VSAN1 IVR VSAN2
Hope this helps,
Mike
user_4444 Thu, 05/07/2009 - 03:30
Thanks.
We have two switches in each fabric and all four switches are IVR enabled. Is that bad design?
Trending Topics: Storage Networking
