Call forwarding towards mobile
Answered Question
May 7th, 2009
this is a debug isdn q931 because the calls do not work towards mobile. Why?
pr 30 23:17:37.921: %LINK-3-UPDOWN: Interface BRI0/3/0, changed state to up
Apr 30 23:17:37.997: ISDN BR0/3/0 Q931: RX <- SETUP pd = 8 callref = 0x6F
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x0183, '3351234567'
Plan:ISDN, Type:Unknown
Called Party Number i = 0xA1, '64470345'
Plan:ISDN, Type:National
Sending Complete
Apr 30 23:17:38.013: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x1, Calling num 3357660463
Apr 30 23:17:38.065: %LINK-3-UPDOWN: Interface BRI0/1/0, changed state to up
Apr 30 23:17:38.889: ISDN BR0/3/0 **ERROR**: L3_Go: Multi nlcb DL_EST, cid 0x2B30 cr 0xEF ev 0x300 ces 1
Apr 30 23:17:38.889: ISDN BR0/3/0 Q931: TX -> CALL_PROC pd = 8 callref = 0xEF
Channel ID i = 0x89
Exclusive, B1
Apr 30 23:17:39.025: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x6C
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
Called Party Number i = 0xA1, '3397654321'
Sending Complete
Apr 30 23:17:39.117: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xEC
Channel ID i = 0x89
Exclusive, B1
Apr 30 23:17:39.465: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8 callref = 0xEC
Cause i = 0x8281 - Unallocated/unassigned number
Progress Ind i = 0x8288 - In-band info or appropriate now available
Apr 30 23:17:39.473: ISDN BR0/3/0 Q931: TX -> DISCONNECT pd = 8 callref = 0xEF
Cause i = 0x8081 - Unallocated/unassigned number
Apr 30 23:17:39.541: ISDN BR0/3/0 Q931: RX <- RELEASE pd = 8 callref = 0x6F
Apr 30 23:17:39.541: ISDN BR0/3/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xEF
Apr 30 23:17:39.549: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8 callref = 0x6C
Apr 30 23:17:39.605: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xEC
Apr 30 23:17:50.613: ISDN BR0/3/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Correct Answer by jijo.paul about 7 years 9 months ago
Cause i = 0x8081 - Unallocated/unassigned number so pls go through the link http://www.cisco.com/en/US/tech/tk801/tk133/technologies_tech_note09186a00800b48cb.shtml
hope this helps
Overall Rating: 5 (1 ratings)
chadlincoln Thu, 05/07/2009 - 04:26
Your called number is 64470345. That is 8 digits. How many does your telco want to see? Can you dial 64470345 from a phone with the exact same CSS that the remote destination has?
Another possibility I've seen is that carriers will use the calling number for authentication to allow or reject the call to go out. Is the calling party going out a number known on your trunk?
Please rate if this helped.
masdan Thu, 05/07/2009 - 04:42
interface BRI0/1/0
isdn map address 3.* plan unknown type unknown
