WIC-4ESW 4-Port
May 7th, 2009
I have cisco 1720 router that was previously installed with a serial interface. The router is used to connect to an ISP leased line. As the ISP changed his equipment, I now need to install a WIC-4ESW 4-Port into my router. So I would like to know which ios version I would exactly need in order to have the card recognized and working. I also need to be able to configure encapsulation.
Thx for your help
Kevin Brennan Thu, 05/07/2009 - 07:40
  • Bronze, 100 points or more
Hi Stephane,
The HWIC-4ESW isnt supported in the 1700 Series. The linked sheet shows the platforms that it is supported in.
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/product_data_sheet0900aecd8016bf0b_ps5855_Products_Data_Sheet.html
The WIC-1ENET might do the job for you though.
Have a look here:
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080088714.html
Kevin
Kevin Brennan Thu, 05/07/2009 - 07:47
Bret,
Well spotted, my mistake!
Kevin
