FTP Issue on Cisco 877
Answered Question
Overall Rating: 5 (2 ratings)
denisoregan Thu, 05/07/2009 - 08:24
Hi, I think I need to put in a ACL forwarding or allowing ftp traffic. Not what Rules are required.
My FTP server is a windows sbs 2003
denisoregan Fri, 05/08/2009 - 05:55
I don't think this is the issue as I've not set the firewall to low so the config now has the line ... ip inspect name SDM_LOW ftp
pompeychimes Fri, 05/08/2009 - 08:17
I know its obvious but is the FTP Server up and running and can you connect to it from inside your network.?
thotsaphon Fri, 05/08/2009 - 11:07
Is your ftp server running with passive mode? If so, You may need a static NAT to accomplish this. Because the server will tell you to randomly use a range of udp ports(1024-65535) to send data. It's not easy to define NAT statement including udp ports.
denisoregan Mon, 05/11/2009 - 00:59
The FTP Server is running as I'm able to access the FTP Server from inside the Network.
I have nat in place
ip nat inside source static tcp 20 xxx.xxx.xxx.58 20 extendable
ip nat inside source static tcp 21 xxx.xxx.xxx.58 21 extendable
thotsaphon Mon, 05/11/2009 - 09:22
what's the exact error you got? Did you pass the authentication process? Can you send/receive any data to/from the server?
denisoregan Wed, 05/13/2009 - 00:39
This is the answer but it came a day late as I had to pay 75euro for the answer.
There was I thinking it was a cisco problem but it was an IE issue.
