Retreive call after fwd by Remote Destination feature
j.mccartney
Is it possible to retreive a call that was fwd'd to say a cellphone (Remote Destination)? I thought once the call is sent to the cell its gone and not possible to retieve it unless you had CVP in your network.
Jaime Valencia
CUCM or CME have no means to do this, once they FW the call to the GW it no longer has control over it
java
if this helps, please rate
java
Jaime Valencia
java
java
