Cisco 7911 time
May 7th, 2009
I'm using cisco 7940 & cisco 7911 with my Call Manager Express. While the time on cisco 7940 is synchronized with the CME, i'm gettting different time on the 7911 phones. How to fix that?
Thank You
valides007 Mon, 05/11/2009 - 06:27
I setup the timezone to est -5, and made sure i have the right time on the router.
I also enterred clock summer-time est reccuring
Again the time on the 7911 phones is 1 hour shifted while the time on 7940 is correct
Adrian Saavedra Mon, 05/11/2009 - 06:35
Did you create cnf-files under telephony service and reset phones?
If the problem persists, did you consider upgrade firmware for your 7911?
Best regards.
