Unity 4.0, Recorded Greeting is not the Greeting being played...Help!!!
uhl_frederick
I have configured a Greeting for a user. When I playback the greeting, all is fine. The problem is when you call into the extension attached to the greeting, you get an older Greeting that user recorded and I have no idea where this is. The Status Monitor states it is playing a greeting for this user, but it is not the one I recorded??
Any insight would be appreciated.
Thank you
Gene
Rob Huffman
Hi Gene,
It almost sounds as if the "Alternate Greeting" is enabled for this user. If so, it will override all other Greetings :)
Hope this helps!
Rob
Rob Huffman
Hi Gene,
Hope this helps!
Rob
Thanks, that was it. Should have checked it.....Didn't figure that the user new how to do that. Thanks again
Hi Gene,
You are most welcome my friend!
User's ...they'll surprise you every time ;-)
Cheers!
Rob
