Unity server out of licenses?
May 7th, 2009
Dear sir,
Based on the attachment, we receive an event id 202 which mentioned unity windows server out of licenses? Is it true? How can we determine the expiry date of licenses in unity 4.0(4) .
Please advise.
Thank you very much.
Overall Rating: 4 (3 ratings)
Jaime Valencia Thu, 05/07/2009 - 08:37
you can go to the GUSI and it will report licensed subscribers and already used licenses to confirm any of that.
java
if this helps, please rate
Ginger Dillon Thu, 05/07/2009 - 08:45
Hi -
Unity is having problems connecting to your partner server. Are you running Exchange onbox? If so, make sure all of your Exchange services are running. If your partner Exchange server is off-box, make sure it is running OK and that you can ping from the Unity server. If off-box, it also helps to have the Exchange server in same subnet as Unity server.
Ginger
fungchai2020 Thu, 05/07/2009 - 08:48
Hi Ginger,
I'm running exchange onbox . :) I'll make sure the exchange services is running. :) Thank you for your help. :)
fungchai2020 Thu, 05/14/2009 - 07:37
Hi Gkavan,
I can't fount "windows License Service" or License Manager on the Service in the Administrative tools. I only can fount License Logging Service in the service --> administrative tools. As shown in attachment , you will see the license logging service. Do you means License Logging Service? Please advise.
Thanks.
