WLAN 2100
Can anybody help me out!! Am working with cisco WLAN controller 2100 with a catalyst switch 3750.After configuration i now see that the WLAN controller cannot ping the switch(3750),neither the switch can ping the management interface of the controller.But when i show cdp ne detail.The two devices can see there neibhour information including there ip address.
come again? you used the managment port on the trunk?
11 Replies 11
gamccall
Level 4
Level 4
Please post the switchport config from the 3750.
this is the config
TEST_WLC#SH RUN
hostname TEST_WLC
ip subnet-zero
ip dhcp excluded-address 172.16.10.1 172.16.10.15 ip dhcp excluded-address 172.16.9.1 172.16.9.15
ip dhcp pool WIRELESS
network 172.16.10.0 255.255.255.0
default-router 172.16.10.1
option 43 hex f
option 60 ascii "c1130"
domain-name wr
lease 0 10
ip dhcp pool WIRE
network 172.16.9.0 255.255.255.0
default-router 172.16.9.1
domain-name wr
lease 0 10
ip dhcp-server 172.16.10.1
ip dhcp-server 172.16.9.1
mls qos map cos-dscp 0 8 16 26 32 46 46 56
FastEthernet1/0/1
description connect to LAP
switchport access vlan 2
spanning-tree portfast
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/16
interface FastEthernet1/0/17
interface FastEthernet1/0/18
interface FastEthernet1/0/19
interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
interface FastEthernet1/0/23
interface FastEthernet1/0/24
switchport mode trunk
switchport nonegotiate
mls qos trust cos
macro description cisco-wireless
auto qos voip trust
spanning-tree bpduguard enable
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface Vlan1
ip address 172.16.9.1 255.255.255.0
interface Vlan2
ip address 172.16.10.1 255.255.255.0
ip classless
ip http server
control-plane
line con 0
line vty 0 4
no login
line vty 5 15
no login
Which vlan is the controller's management address on?
On the controller, is the management interface configured as tagged or untagged?
Best practice is to specify a native vlan on the Catalyst's switchport, and leave the management interface untagged.
The management interface is untaged an is on vlan 1 which is the default vlan of the switch.
back to gam's response..
Under the controller-->interfaces-->managment interface-->Vlan Identifer
What do you have in the VLAN Identifer "0" or "1" ?
Normally when you cant access the managment interface its 90% of teh time a tag issue. At least that has always been what i seen ...
pls check the new config of both devices
TEST_WLC#SH RUN
hostname TEST_WLC
switchport access vlan 1
interface FastEthernet1/0/15
mls qos trust cos
auto qos voip trust
interface Vlan1
interface Vlan2
ip classless
ip http server
control-plane
line con 0
line vty 0 4
no login
line vty 5 15
no login
CONTROLLER 2100
(Cisco Controller) >show interface summary
Interface Name Port Vlan Id IP Address Type Ap Mgr Guest
ap-manager 1 untagged 172.16.9.3 Static Yes No
management 1 untagged 172.16.9.4 Static No No
virtual N/A N/A 1.1.1.1 Static No No
I never used VLAN 1 on the controllers. Ive always used "other non-vlan 1" VLANs and the native statements.
Try this ... move the switch port to access and see if you can hit the controller. If you can you know you have a miss match.
Although you shouldnt have to use the native stament for VLAN1 but you can also try adding that and see if you can hit it ...
Also put something else on the switch and see if you can hit that device ...
btw... are you plugged into port 1 on the controller to your switch... thats what you have the man interface pointing at !?
mls qos trust cos
Am using untagged vlan on the controller which is vlan 0 by default.i have use it as an access it does not hit it....
But thanks so much i have got it i used the management port on the trunk and u see it ping the switch verse versa
Yes. I used the managemen port which is port 1 and i connected it to the trunk port of the switch which is port f1/0/24 on the switch.I used a cross over Cable.
yup yup... great! if you found this post help please rate it ! Working hard for a star! lol
