05-07-2009 08:39 AM - edited 02-21-2020 03:26 AM
Hello, I'm trying to set up an Easy VPN on a cisco 871 router. We are doing it in extended network mode, and the VPN connects fine. But I need to know what more I need. In theory, when you connect to an ezvpn extended network mode you get an IP of the pool range defined on the server. What you have to configure to have that ¿? I don't have any local pool defined in the config.
Thanks all !
05-08-2009 01:24 PM
You can simply define a DHCP pool on the 871 router so that attached clients can be served an address locally.
05-09-2009 05:40 AM
And is there a method to attach that DHCP pool to the EZVPN config ?
