Translation rules on gateway with mgcp controlled E1
Hi All
I would like to know if is possible build a translation route to a voice interface that for all traffic that is comming with a size of 8 (XXXXXXXX) digits put in front a 09, I know that a Gateway MGCP is controlled by Callmanager I could manage digits with the parameters ''prefix DN'' on inbound calls in the call routing information but this parameters I will put a digit 9
So that way any inbound number (caller id) I will put in front the 9 for do a redial feature.
Please your suggest
Andres
Overall Rating: 5 (1 ratings)
chadlincoln Thu, 05/07/2009 - 10:03
  • Bronze, 100 points or more
You cannot do this if it is MGCP controlled. All control is done on through the gateway configuration on the UCM.
Please rate if this helps.
