CCX 7.01 Repository Data Store Error
May 7th, 2009
Hi there,
We installed a CCX 7.01 and everything was working fine till we had to restart the server. Now it shows up this message when we access the Scripts Menu "Error reading scripts, Repository Data Store error," it says to check it in the Control Center, when we accessed the Control Center it has some services unavailable. I attached the image of the Control Center, by the way we just installed the SR1 and SR2 and it still has the issues described above.
Thanks in advance.
Clifford McGlamry Tue, 06/02/2009 - 14:53
  • Silver, 250 points or more
  • Community Spotlight Award,
    Best Publication, November 2015
What did you do to fix it? Mine is having the same issue.
justincohen Wed, 11/11/2009 - 13:41
Yeah i'm having the same issue as well right now.
Why don't posters post their findings when they fix a problem.
Clifford McGlamry Wed, 11/11/2009 - 13:53
Sometimes they are only resolved via TAC cases.
In our case, some of the underlying core services weren't running. Check and make sure you've got SQL server running, check you conneciton over to Callmanager (AXL provider) and consider rebooting things.
